Cube 60 AC - failover to 5GHz?
Does anyone have a blessed config for using the 5GHz failover on the Cube 60 AC in a point-to-point setup? Mind sharing? I haven’t been able to find such a config in the docs.
http://forum.mikrotik.com/t/default-conf-cube-60g-ac-ptp/145573/1
You have several options
For starters , take a look at spanning-tree for your switches on both ends of your link.
