Cube 60 Pro AC kicked by PoE Switch
After boot the PoE Switch (561839 from intellinet) kicks the Cube. This does not happen with Mikrotik’s supplied PSU.
Said switch supports 802.3at, so its really not a weak one.
I assume there is a power surge and Mikrotik saved on local capacitance (maybe because of space constraints). Unfortunately while conventional AC/DV power converters are very forgiving with power surges, PoE switches are not.
Anything official?
