Cube 60Pro ac - mount for a network device
Hi everyone,
Maybe is easy question, but I search mount for the device Cube 60Pro AC .
I'm search this mount: https://mikrotik.com/product/solidmount , but this is not sugested.
The second is this: https://mikrotik.com/product/QMP .
I would like prefer first mount because in my opinion the second is similar orginal mount from box with Cube 60pro ac.
I waiting for answer.
Those cubes have a "peculiar" way to mount, the device itself has just the hollow tube on the back, so you need anyway the "Cube mount bracket" coming with the device or you need to hack together a pipe of the right diameter to replace it, see also:
Cube 60Pro ac wall mount - QMP? - #2 by jaclaz
