Can the QMP be used to attach a Cube 60Pro-ac to a wall without any modification?
Is there a photograph showing how the two fit together?
Thanks.
Thanks.
The QMP comes (but the good Mikrotik guys do not show an explicit/clear photo of them) with two “attachment” devices:
You can see it (once you know it exists, in the second photo of the product:
https://cdn.mikrotik.com/web-assets/rb_images/1445_hi_res.png
It is clearer in this photo:
https://www.voipmarket.it/2845-large_default/qmp-mikrotik-quickmount-pro.jpg
it is the thingy on the left.
See also this video:
https://www.youtube.com/watch?v=nxb0_ZEzoas
Would this fit in the Cube Pro directly? ![]()
I don’t think so, but you can mount on the QMP any device that you would normally pole mount, using the hose clamp, including the Cube, it won’t be pretty, but it will work.
