Cube Lite60 - PtP
Is it possible to use two Cube Lite60 devices as a point-to-point link? L3 license should be OK but the HW documentation is very brief and it is not clear if there is a such capability.
Thank you
Cube Lite60 is designed to be less visible than a traditional dish CPE, but make no mistake – it’s still a real powerhouse. The effective point-to-point distance between Cube Lite60 units is up to 800 meters, point-to-multipoint – up to 500 meters.
You are right. Thank you. It seems pretty clear and I missed it :-/
Moreover, I was hoping that there is someone with personal experience.
Possible but it is limited by the non gigabit Ethernet Interfaces…
More than 100MBit are not possible
