CubeG-5ac60ay 5Ghz flapping
I have multiple CubeG-5ac60ay-SA APs with CubeG-5ac60ay clients setup with "active backup" bonding and have NAT setup in the CubeG-5ac60ay.
The problem is that if the 60GHz connects first, the 5GHz will only stay connected for about 10 seconds before disconnecting.
The APs say that the client is disconnecting for "management-protection failure", but the clients say "lost connection, registered to other device in network".
The only way it seems I am able to get the 5GHz from constantly disconnecting, is to disable the 60GHz for a few seconds, wait until the data rate increases from 6Mbps, and then re-enable the 60GHz. The clients will then stay connected to the 5GHz AP for days or longer without issue.
Is there something else I should change on 5GHz config (AP or client) to prevent the disconnects? I mostly followed the Fail-over PtMP CLI example directions. Could something in my firewall rules on the clients be causing the problem somehow?
AP export:
model = CubeG-5ac60ay-SA
add admin-mac=FF:FD:74:D6:2B:99 auto-mac=no name=bridge1
/interface w60g
set [ find ] disabled=no frequency=60480 isolate-stations=no name=wlan60-1 password=MY-PASSWORD
put-stations-in-bridge=bridge1 region=usa ssid=MY-SSID
/interface w60g station
add mac-address=04:CE:14:FA:2A:1D name=wlan60-station-1 parent=wlan60-1 remote-address=04:CE:14:F7:D0:E7
add authentication-types=wpa2-psk group-key-update=15m management-protection=allowed
management-protection-key=MY-KEY mode=dynamic-keys name=wlan1 wpa2-pre-shared-key=MY-PASSWORD
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac basic-rates-a/g="" disabled=no frequency=5765
installation=outdoor mode=ap-bridge security-profile=wlan1 ssid=MY-SSID supported-rates-a/g=""
add bridge=bridge1 interface=wlan1
Client export:
> ```text
# model = CubeG-5ac60ay
/interface w60g
set [ find ] disabled=no mode=station-bridge name=wlan60-1 password=MY-PASSWORD region=usa ssid=MY-SSID
add authentication-types=wpa2-psk management-protection=required management-protection-key=MY-KEY mode=dynamic-keys name=wlan1 supplicant-identity=stage0 wpa2-pre-shared-key=MY-PASSWORD
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac country="united states" disabled=no disconnect-timeout=15s frequency=auto installation=outdoor keepalive-frames=disabled mode=station-bridge radio-name="Stan Vaughn" scan-list=5745-5825 security-profile=wlan1 ssid=MY-SSID
add name=LAN
add exclude=LAN include=all name=WAN
/interface bonding
add mode=active-backup name=bond1 primary=wlan60-1 slaves=wlan60-1,wlan1
add interface=ether1 list=LAN
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=drop chain=input comment="drop all not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="fasttrack established, related" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
add action=masquerade chain=srcnat out-interface-list=WAN src-address=192.168.5.0/24
Even after upgrading to 7.13 and trying MANY deferent wireless settings (nstream, security, management protection, etc), we are still experiencing the same problem. It seems like when the 5GHz is flickering that the bonding may be having a problem and dropping some packets on the 60GHz.
Try 60G: isolate-stations=yes on AP
