Hello Dear MikroTik forum
I am here with really strange behaviour on one of our CubeSA 60GHz APs. Device is running for about half year with only ONE client connected and we noticed it started to reboot itself. From observation, device just runs out of RAM and then restarts. But i noticed it only happens when there is no client connected (i suppose client started to turn off his the device to save electricity or something, does not matter).
Once the client disconnects, the device runs normally for about a hour and then RAM starts filling up until it crashes. I have two screenshots of memory usage here.
In the first image you can see the device run normally, until 10 PM, then client disconnects and problem occurs, fill up RAM → Crashes → Reboot → Repeat
The blank usage from 6 AM was caused device not booting again, i rebooted it remotely via POE Switch.
Then the device repeats it cycle until client connects again at about 1 PM, then the RAM stops filling but keeps the usage high until i rebooted it at 6 AM next day.
I post my config here, i replaced all sensitive info with ‘notforyou‘
add admin-mac=04:CE:14:F6:F8:3A auto-mac=no name=bridge1 port-cost-mode=short
protocol-mode=none
/interface w60g
set \[ find \] disabled=no frequency=66000 name=wlan60-1 password=
"notforyou"
put-stations-in-bridge=bridge1 region=no-region-set ssid=notforyou
/interface w60g station
add mac-address=04:CE:14:F6:F8:3A name=wlan60-station-1 parent=wlan60-1
remote-address=F4:1E:57:E5:31:16
set \[ find default=yes \] supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods=""
management-protection=allowed mode=static-keys-required name=notforyou1
static-algo-0=40bit-wep static-key-0=notforyou supplicant-identity=""
add authentication-types=wpa2-psk eap-methods="" management-protection=
allowed mode=dynamic-keys name=notforyou2 supplicant-identity=""
wpa2-pre-shared-key=
"notforyou"
/interface wireless
set \[ find default-name=wlan1 \] band=5ghz-onlyac country=no_country_set
default-authentication=no disabled=no frame-lifetime=10 frequency=5540
frequency-mode=superchannel hw-protection-mode=rts-cts
hw-protection-threshold=256 hw-retries=5 mode=ap-bridge radio-name=
notforyou
security-profile=ISFO_WPA ssid=notforyou wireless-protocol=802.11
wps-mode=disabled
add name=dhcp_pool0 ranges=172.17.220.10-172.17.220.100
add address-pool=dhcp_pool0 interface=bridge1 lease-time=20h name=dhcp1
/snmp community
set \[ find default=yes \] addresses=notforyou/32 read-access=no
add addresses=notforyou/32 name=notforyou
/user group
set read policy="local,telnet,ssh,read,test,winbox,web,sniff,api,romon,rest-ap
i,!ftp,!reboot,!write,!policy,!password,!sensitive"
add bridge=bridge1 interface=wlan1
/ipv6 settings
set disable-ipv6=yes
add address=172.17.220.1/24 interface=bridge1 network=172.17.220.0
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=172.17.220.10 client-id=1:f4:1e:57:e5:31:16 comment=
notforyou mac-address=F4:1E:57:E5:31:16 server=dhcp1
add address=172.17.220.0/24 dns-server=notforyou gateway=172.17.220.1
ntp-server=notforyou
set servers=172.16.1.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=88
set api disabled=yes
set api-ssl disabled=yes
/radius
add address=notforyou require-message-auth=no secret=notforyou
service=login
/snmp
set enabled=yes trap-community=notforyou trap-generators=""
trap-version=2
/system clock
set time-zone-name=Europe/Prague
/system gps
set enabled=yes port=gps
/system identity
set name=notforyou
/system note
set show-at-login=nos
/system ntp client
set enabled=yes
/system ntp client servers
/user aaa
set exclude-groups=full use-radius=yes
Sw Version is 7.18.2, also this is a second device, we replaced first one with this, because we tought that the device is faulty, but now the second device behaves the same.
If anyone encountered this, or have an idea, what might cause this or how to trace it, i will be happy for any feedback. Thank you.
