CUP Load 100% :( :( :( :( please help me some one
My Mikrotik cpu load 100% how can i solve the problem please some one help me.
Running PCQ + Mangle at that mikrotik … Please expert help me
i attached screen shot
At least the screenshot shows what model router you have.
Perhaps you should post your queue settings. (Use command-line export, and not screenshots)
Also post an export of your mangle rules.
If you disable the queues, does the CPU utilization return to normal levels?
I highly recommend send your export from queue and mangle
Sent from my SM-N910C using Tapatalk
Thanks For Your Reply Here is queue export
/queue type
add kind=pcq name=PCQ_DOWN pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=60M pcq-src-address6-mask=64
add kind=pcq name=PCQ_UP pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=60M pcq-src-address6-mask=64
add kind=pcq name="test down" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=70M pcq-src-address6-mask=64
add kind=pcq name="test up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=70M pcq-src-address6-mask=64
add kind=pcq name=Youtube_Dw_Lavel3 pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=500KiB pcq-rate=20M pcq-src-address6-mask=64
add kind=pcq name=FTP_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=50M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=FTP_UP pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=50M pcq-src-address6-mask=64
add kind=pcq name=Live-TV_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=2M pcq-src-address6-mask=64
add kind=pcq name=Live_TV_Up pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=2M pcq-src-address6-mask=64
add kind=pcq name=Evu-Tube_Down pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=20M pcq-src-address6-mask=64
add kind=pcq name=Evu_Tube_Up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=50M pcq-src-address6-mask=64
add kind=pcq name=1300tk_up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=7M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=youtube_Toamto_Up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=15M pcq-src-address6-mask=64 pcq-total-limit=
100000000KiB
add kind=pcq name=youtube_Toamto_dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=15M pcq-src-address6-mask=64 pcq-total-limit=
100000000KiB
add kind=pcq name="500 tk_up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=2M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name="500 tk_DW" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=4M pcq-src-address6-mask=64 pcq-total-limit=200KiB
add kind=pcq name=800tk_down pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=6M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=800TK_Up pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=3M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name="1000 tk_up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=4M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name="1000 tk _dw" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=8M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name="1100 tk_up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=3M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name="1100 tk_dw" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=4M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name="1300 tk_Double_up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=5M pcq-src-address6-mask=64 pcq-total-limit=
100000000KiB
add kind=pcq name="1300 tk_dw" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=5M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name="1500 tk_up" pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=12M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name="1500 tk_dw" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=6M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=2000tk_Down pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=7M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=2000tk_up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=7M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=Youtube_Up_Lavel3 pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=15M pcq-src-address6-mask=64
add kind=pcq name="1 MB_Dw" pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=1M pcq-src-address6-mask=64
add kind=pcq name=1MB_Up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=1200k pcq-src-address6-mask=64
add kind=pcq name=pcq_downsteam pcq-classifier=dst-address pcq-rate=4M
add kind=pcq name=pcq_upstream pcq-classifier=src-address pcq-rate=6M
add kind=pcq name=BDIX_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=100M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=BDIX_Up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=50M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=Free_DW pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=3M pcq-src-address6-mask=64
add kind=pcq name=Free_up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=4M pcq-src-address6-mask=64
add kind=pcq name=Media-1_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=100M pcq-src-address6-mask=64
add kind=pcq name=Media-1_up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=1G pcq-src-address6-mask=64
add kind=pcq name=1M_You_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-rate=12M pcq-src-address6-mask=64
add kind=pcq name=1M_You_Up pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-rate=12M pcq-src-address6-mask=64
add kind=pcq name=500TK-Night_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=4M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=500TK_Night_UP pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=4M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=800TK_Night_UP pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=6M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=800TK_Night_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=6M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=1000TK_Night_Dw pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=8M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=1000TK_Night_UP pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=8M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
add kind=pcq name=1100TK_Night_DW pcq-classifier=dst-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=10M pcq-src-address6-mask=64 pcq-total-limit=1000000000KiB
add kind=pcq name=1100_TK_Night_UP pcq-classifier=src-address pcq-dst-address6-mask=64 pcq-limit=100KiB pcq-rate=10M pcq-src-address6-mask=64 pcq-total-limit=100000000KiB
/queue simple
add max-limit=85M/85M name=ibrahim-Home-Internet queue=default/default target=172.16.0.12/30
add name=Internete_You packet-marks=InterneteYoutube_pack priority=2/2 queue=Youtube_Up_Lavel3/Youtube_Dw_Lavel3 target=""
add dst=103.25.120.112/28 max-limit=1G/1G name=Media-1 queue=Media-1_up/Media-1_Dw target=""
add dst=Starget_Youtube limit-at=310M/310M max-limit=310M/310M name=ibrahim-Home-Youtube priority=1/1 queue=default/default target=172.16.0.16/30
add dst=Starget_BDIX name=IBRAHIM-BDIX target=172.16.0.20/30
add dst=Starget_BDIX max-limit=1G/1G name=Internete_BDIX queue=default/default target=""
add dst=Internete_Internet name=1MB queue="1MB_Up/1 MB_Dw" target=10.222.44.0/24,10.223.44.0/24
add dst=Internete_Internet name=Free-Double queue=Free_up/Free_DW target=10.222.40.0/24
add dst=Internete_Internet limit-at=2200k/2200k max-limit=3M/3M name=Medical target=103.3.224.172/32
add dst=Internete_Internet name="2000 TK" queue=2000tk_up/2000tk_Down target=x.x.x.x/x
add dst=Internete_Internet name="800 TK" queue=800TK_Up/800tk_down target=x.x.x.x/x10.223.34.0/24
add dst=Internete_Internet name="1000 TK" queue="1000 tk_up/1000 tk _dw" target=10.223.35.0/24,10.222.35.0/24
add dst=Internete_Internet name=500TK queue="500 tk_up/500 tk_DW" target=10.222.48.0/23
add dst=Internete_Internet name=queue2 queue="500 tk_up/500 tk_DW" target=10.222.47.0/24
add dst=Internete_Internet name=queue1 queue="500 tk_up/500 tk_DW" target=10.222.32.0/23
add dst=Internete_Internet name="1100 TK" queue="1000 tk_up/1100 tk_dw" target=10.222.36.0/24
add dst=Internete_Internet name="1300 TK" queue="1300 tk_Double_up/1300 tk_dw" target=10.223.37.0/24
add dst=Internete_Internet name="1500 TK" queue="1500 tk_up/1500 tk_dw" target=10.222.38.0/24
Mangle
/ip firewall mangle
add action=mark-routing chain=prerouting comment=ISP dst-address-list=!ByPass new-routing-mark=ISPe-Net passthrough=yes src-address-list=Stagate_Internet
add action=mark-connection chain=prerouting comment=ISPe_Youtube dst-address=x.x.x.x/x new-connection-mark=ISPe_Youtube passthrough=yes
add action=mark-packet chain=prerouting comment=ISPe_Youtube connection-mark=ISPe_Youtube new-packet-mark=ISPeYoutube_pack passthrough=no
yes sir if i disable queues ... CPU return to normal level.
/queue type
100000000KiB
100000000KiB
100000000KiB
/queue simple
add dst=Internete_Internet name="2000 TK" queue=2000tk_up/2000tk_Down target=x.x.x.x/24
add dst=Internete_Internet name="800 TK" queue=800TK_Up/800tk_down target=x.x.x.x/24,10.223.34.0/24
Mangle
/ip firewall mangle
add action=mark-connection chain=prerouting comment=ISPe_Youtube dst-address=45.118.245.64/26 new-connection-mark=ISPe_Youtube passthrough=yes
This seems like it might be too much PCQ, especially if this is a core router that gets thousands of connections going through it.
Yes sir this is a core router … can i get any solution for this ? :frowning:
Since PCQ = “fair queue” - you should probably just make far fewer traffic classes and let the sub-streams that form there duke it out for bandwidth sharing within the class.
In fact, you may be able to easily get by in just defining a few priority levels of traffic and giving a CIR to each class and not worry about time of day, etc.
So if streaming is a problem during business hours, but not at night, all of your streaming matches should just get a single simple queue that has lower priority than other queues, and a CIR of something like 25% of the pipe. If nobody’s doing anything else, they may as well be able to stream, but the streams have to give way to email and so forth…
Just my $0.02’s worth.
CIR = committed information rate = guaranteed minimum.
Anything above the guarantee is only given if available.
Hi, your problem is easy as this:
add action=fasttrack-connection chain=forward disabled=no
