how is that possible …?
someone has an idea?
Regards, mdminfo
Regards, mdminfo
It should not be possible, but it seems it is. You are fine as long it is not using that 6Mbit/s speed or maybe it is working with the MT 802.11b clients just fine.
As you can see, it is showing “last measured” more than 5 minutes ago. It appeared for a second while you were still negotiating the connection, when the rates were confirmed, it is not used anymore, but it still stays in this list. you will see that the time will increase, since last seen.
