Curl and php in the login?
Hi peoples,
I’m developing a mikrotik interface, I’m making logins tests but I can not frame the schema of mikrotik for this.
I want know if I can use the curl for send the request of login at mikrotik.
Please Help meeee!!
My english is not good, Sory.
if you want to use curl+php on the router then it’s not possible
Thanks normis,
but i don’t want use curl+php on the router. I replaced the login.html page of mikrotik for redirect to a central login, a external application, a portal captive. This application is a radius admin with a login page. This page send the login request to the mikrotik with curl.
This is schema that I want implement.
Thanks.
up
if your sending them to a radius login / signup then why not use radius to authenticate them?
The reference manual of mikrotik RouterOS said
  • Modify login page of the HotSpot servlet to redirect to the external authentication…
  • The external server can log in a HotSpot client by redirecing it back to the original HotSpot servlet login page, specifying the correct username and password…
I can make this, but I want make the second point with curl. If it is possible.
My english is not good.
Sory and Thanks.
Any idea ?
I’m loggin users using an external page with RADIUS accouting, i don’t want redirect them to the servlet (Ex. 192.168.0.X/login.) I Want to add users remotly, using CURL. Can you help me ? It’s posibble ?. I Have used the PHP API for logout.
Regards,
You don’t want to use CURL because the request for login has to come from the client and not from the server, a CURL request from the server would log the server in. You can, however, redirect the user to http://router.name.or.ip/login?username=username&password=password&dst=final.redirect.url and have the client do he login, and be redirected back to the external server. The quoted string requires PAP or HTTPS enabled on the Hotspot, CHAP I am sure is possible but I have never used it.
