current license allows only 10 active sessions????
Good Day,
We have level 4 licence on mikrotik ros version 2.9.42, and when the 11 user tries to connect, they get disconnected, and log says current licese allows only 10 users.
What can be done to remidy this, as we do have level 4 licence and this allows 200 pppoe connections.
Please help, quite urgent. :exclamation:
Please see User Manager limitations on this page:
http://www.mikrotik.com/software.php
thanks friend @normis
i understood.
do you remember TCP-Becak, i always rmember you.. :wink:
peace man
Hasbullah.com
TCP-over-becak is the best :slight_smile:
thanks friend, i will keep it...
Hasbullah.com
Hi took a look, and noticed that only ros v3 and unlimited offer more users.
Looks like we will have to upgrade to level 6 licence
thanks
or upgrade to v3 …
Hi ,
Is there a work around by creating another server for another 10 clients, or is 10 the limit.
This is again on level 4 licence
Hope that there is a workaround.
no there is not, otherwise why would anyone need the L6 license?
Just want to say thanks for the reply, I will have to use pppoe with queues untill i have got the new licence key
ofcourse..!
maybe they want nice to sleep..... :laughing:
regards
Hasbullah.com
