Custom center frequency
Is it possible to set an arbitrary center frequency (assuming it is in the card’s supported range)?
For example - A 5-MHz wide channel operating with a center frequency of 2445MHz? Is this possible?
No, you can not pick an arbitray frequency, but using SuperChannel gives you the best selection of none standard frequencies with a resolution of about 2.5mhz
