custom hotspot GET variables ?
This logs in a hotspot user:
http:// ip.address/login?username=xx&password=xx
Then, I can access the username in the on-login script with
:log info $user
That’s good so far.
However, I would like to be able to log other custom variables, for example:
http:// ip.address/login?username=xx&password=xx&customvariable=xx
Then use :log info $customvariable in the on-login script … that doesn’t work. Is there anything that WILL work? Anyway to get custom data into the routerbox like that?
