Custom new window size on HotSpot Connection Status
Hi There,
We success to make custom login, logout and status screen on hotspot menu.
The problem is.. when user success to log in, the new screen (status) is open with small size.
Is there any way to adjust this status screen size, so user can see our company logo without having resize the window ?
Regards
Paul
you can change the popup window size with some javascript. search the original file source and you will probably find where it’s size is set
Is there any way to turn connection status window into a bottom float bar instead of popup window so it will always appears.
Hi Prawira,
Could you please post the tecnique how to customize the Hostspot Log in /Log out nd Status window? I tried to do it but when I put the file in my Hotspot it didn’t give user to access.
Please help.
  • LEO
