Custom .npk
Hello.
This isn’t a “NECESSARY” feature but,
Is it possible to customize the Combined Package with the desired packages?
IE: In a CPE, I usually load the combined package then disable some un-needed and add wireless-test package.
It would be cool to load an unique custom package.
If this means to change totally the packaging system, just forget it. :laughing:
I guess that Mikrotik doesn’t will allow this..
Max
why don’t just use a set of needed packages? so it will not be necessary to disable something
That might be good aswell, but i was looking for a way to simplify the way to upgrade a router.
It’s not a big issue as i stated already, i was just curious if it could be possible to.
