Custom Tool and IP referencing
Hi Dude Community,
I assume this has likely been answered however I haven’t seen a definitive threat.
Simply I want to reference the second or third or 8th IP address that a device might have in a custom tool - basically one device with multiple services.
You can use the [Device.FirstAddress] variable but that’s it - I used the custom variables however that’s limited and not really what I’m after.
Can anyone advise if you’re able to reference more IP’s or if this is a feature that’s “in the pipeline”
Cheers,
Garreth
You can run a tool directly from any associated IP:
