Customer Public IP
Our current setup has an ap directly connected to fiber on Ether1. We are also using broadband-over-powerline devices as customer devices, and a bridged wireless setup currently while we are still deploying fiber throughout out network.
Ether1 has a Public IP: XX.XXX.XX.XXX
The bridge and all customer devices are behind NAT and on their own Private Network: 10.10.100.1/24
The customer device takes care of customer privatization issues, and that has not been a concern.
What I would like to do and have not has much succes with, is providing a customer with a public ip. I have tried the netmap, and toyed with dst-address, but my lack of networking knowledge is keeping me from getting it to work.
If anyone could assist with mapping a public ip to a private one, 1address:1address, I would appreciate it. I can’t seem to get this to work after trying some different combination of what I listed above.
Thanks for any help you could provide…
yes,
i hope on red color report screen will help you make mapping public to local one:
regards
Hasbullah.com
Do you want to assign on client a public IP or all? For one client the best way to do it is via one to one nat. I am using this and it work perfectly.
YOu can find how to do it in this forum or manual.
Let me know if you need I can get the config.
Regards,
Robert Macri
can we put the real IP on client side directly without NAT ? let’s say that client is connected alone to an interface ..
samsoft08,
yes you can put another public IP to local interface, just make sure that this subnet is routed to the particular router public IP address.
at last a reply !!! thanx alot ..
you said another public ip to the local interface !! i cant get it ..
would you please give me an example how to do it for this case :
1- a public IP’s of /28 subnet
2- 1 local interface to a group of clients
3- 1 local interface to a single client ( another MT )
i did this config , its working but with INCREDIBLE connect-disconnect of MSN & yahoo messengers !!!
[admin@MikroTik] ip address> pr
 #   ADDRESS               NETWORK            BROADCAST          INTERFACE
 0   192.168.1.250/24     192.168.1.0         192.168.1.255         bridge1
 1   a.b.c.21/28             a.b.c.16              a.b.c.31                 internet
 2   192.168.2.250/24     192.168.2.0         192.168.2.255          R-MT
 3   a.b.c.23/28             a.b.c.16              a.b.c.31                 internet
[admin@MikroTik] ip route> pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf
 #            DST-ADDRESS            PREF-SRC        G GATEWAY         DISTANCE INTERFACE
 0 ADC        a.b.c.16/28              a.b.c.21                                                 internet
 1 ADC      192.168.1.0/24          192.168.1.250                                          bridge1
 2 ADC      192.168.2.0/24          192.168.2.250                                          R-MT
 3 A S          0.0.0.0/0                                        r a.b.c.17                       internet
[admin@MikroTik] ip firewall nat> pr
 0     chain=dstnat action=dst-nat to-addresses=192.168.2.251 to-ports=0-65535 dst-address=a.b.c.22
 1   chain=srcnat action=src-nat to-addresses=a.b.c.22 to-ports=0-65535 out-interface=internet
     src-address=192.168.2.251
 2   chain=srcnat action=src-nat to-addresses=a.b.c.21 to-ports=0-65535 out-interface=internet
 3  ;;; Proxy Redirecting
     chain=dstnat action=redirect to-ports=3128 in-interface=bridge1 dst-port=80 protocol=tcp
R-MT is the interface which is connected to the remote MT..
Hello samso....
yes, as my screen captured and i used it several months ago and until now working fine.
again, when you want one local address as public one, at my first post should be work.
you must add public address as broadcase itself.
/ip add add address=a.b.c.22/32 interface=internet
and create any rules Network Address Translation:
/ip fi nat add chain=dstnat action=dst-nat to-addresses=192.168.2.251/32 to-ports=0-65535 dst-address=a.b.c.22/32
/ip fi nat add chain=srcnat action=src-nat scr-address=192.168.2.251/32 to-ports=0-65535 to-address=a.b.c.22/32
i think with this rules should be ok... :wink: and i hope will closed your problem
again, i don't have any problems about this.. sorry...!!!
regards
Hasbullah.com
Nat
thats fine just one thing , i put public IP /28 on the internet interface not /32 is this will cause a problem , its working fine as i think !!!
/ip add add address=a.b.c.22/28 interface=internet
