where is “Customers” menu on ROS 7 ?
thanks
thanks
What is “Customer” menu ?
Not sure if it is what you are looking for, but from the documentation: Each user has access to his personal profile using a WEB interface. The WEB interface can be accessed by adding “/um/” directory to router’s IP or domain, for example, http://example.com/um/.
UserManager’s administration has been moved in WebFig/WinBox to its own top level menu. More information in this forum post.
on old wiki mikrotik, there is Customer on Usermanager
This is, as you said, the old wiki for versions prior to 7.
I pointed you to the documentation for RouterOS V7.
