Customizing hotspot files not used
On a RB751G-2HnD I have set up a hotspot using the default folder hotspot but if I edit the hotspot/login.html the changes appear not to be presented on the hotspot. I just changed the spelling to make sure that it wasn’t any syntax. Even rebooting doesn’t seem present the change. Any suggestions?
It has always worked fine for me. Are you sure that once you have made the changes you have uploaded the new file?
It works here too. Since the file is a html file extension, maybe it is being cached in your browser? Try a forced refresh, or clear your web browser cache.
