Hi am new to Mikrotik and RouterOS and I am setting up a config file so that I can easily program multiple routers quickly. I was wondering if its possible to edit the quickset menu more then just removing options that are already there. For example I like the way the “Home AP Dual” page is set up the only thing I’d want to add is a option for “Router Identity”. It is available under other Quicksets such as WISP AP but not Home AP Dual. WISP AP also has everything I’d need but it doesn’t have the option to change both 5 and 2.4 Ghz SSID.
I was just wondering if I was looking in the wrong place or if you can only remove items. Thanks!
Customising the built in menu pages is not possible.
Ok, I’ll stop searching for a way lol. Thanks!
