hi all
just need some help… can you schedule internet to cut off on a certain date for a particular user in mikrotik without using usermanager hotspot?
Use firewall time matcher or scheduler.
hi rich
thank you for the reply. lets say i have some simple queues on my mikrotik and i want a client to be cut off after 30 days. can you please give an example of the firewall time matcher rule that i will use. i nhave tried to look for a solution but all that iam seeing are time based not date based
thanks
thanks RICH
lets say you have simple queues and you want to cut off internet for certain IPs after 30 days. can you give an example of the rule that i will use.
Good evening
can anyone help on this??
Who is aking here?
madhau
or
sammamwadi
If some is wrong in one post, you can edit it instead of posting a new one.
hi
sorry for the mix up in the accounts. its sammamwadi asking…
