this is my session config:
add in-filter=UTRS-IN instance=MYISPNAME max-prefix-limit=500 max-prefix-restart-time=10m multihop=yes name=UTRS out-filter=UTRS-OUT passive=yes remote-address=154.35.x.x
remote-as=64496 tcp-md5-key=PASSWORD ttl=default
in this case when i announce /32 to UTRS i wcan see attacks towards my network and also i tried remove no-export tag from my as number and tried tag it with 64496:0 only but it did not work,
also they informed me they can see my routes ,
any idea ?
Thank you.
Don’t remove, advertising 25-32 prefixes to URTS is the whole point of the service…
Likely the OP and other posters issue is they are expecting URTS to stop their ddos attack where it will only help if the attack is originating from the network of a URTS member, you also need to be advertising a black hole via bgp community to your upstream providers!
