D-link DWM-156 GSM modem Works with mikrotik
good news
[dark@RB951G] > interface ppp-client print detail
 0  R name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb1 data-channel=2 info-channel=2 apn="RighTel" pin="" user="" password=""
      profile=default phone="*99#" dial-command="ATDT" modem-init="ATZ;AT+CFUN=1;ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0" null-modem=no dial-on-demand=no
      add-default-route=no use-peer-dns=yes keepalive-timeout=10 allow=pap,chap,mschap1,mschap2
tnx; I am test it and connected, but not any interfaces add in interface list
Hi…
Use this code it`s work for me…
/port
set 0 name=usb1
/interface ppp-client
add apn=RighTel data-channel=2 dial-on-demand=no info-channel=2 modem-init=
“ATZ;AT+CFUN=1;ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0” name=RighTel phone=*99#
port=usb1
/ip neighbor discovery
set RighTel discover=no
Just replying in this old topic because I coudn’t configure it with above settings.
On latest Mikrotik 6+ you should create the interface first, without configuring the data & info channel.
Once created disable the interface. Or enable and disable it. Then manually add the data & info channel with value 2.
/interface ppp-client add name=INTERFACENAME port=usb1 apn=APN dial-on-demand=no pin="" user="" password="" profile=default dial-command="ATDT" null-modem=no add-default-route=no keepalive-timeout=10 allow=pap,chap,mschap1,ms
chap2 mrru=disabled modem-init="ATZ;AT+CFUN=1;ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0" phone=*99#
Don’t forget to add NAT masquerade rule.
