Daily Report Script
My problem is the following:
I would like to have a script that stores the movements of all users in a file and then send it as an email to me.
I need infomation about:
Username
Download
Upload
Uptime
and more…
This information I can get all from the User-Manager with:
/tool user-manager session print
But I can’t select only one day…
This is my try:
:log info "Start DailySessionReport Script"
:local count
/tool user-manager session print append file="total_session.txt"
:delay 2s
/tool user-manager session print value-list file="daily_session.txt"
:set count [/tool user-manager session print count-only;]
:local i [/tool user-manager session print count-only;]
:local x 1
:while ($i >= ($x )) do={
/tool user-manager session print;
/system script run Remove
:set x  ($x + 1);
/tool e-mail send to="xxxx.xxxxx@xxxxx.de"  body="Bewegungen im PPPPPP-XXXXX Es wurden $count Bewegungen gezählt. " subject="Bewegungen im PPPPPP-XXXXX " file=("daily_session.txt")
:log info "END DailySessionReport Script"
And here I delete step by step each entry:
:log info "Remove Start"
/tool user-manager session remove numbers=0
:log info "Remove End"
but there I delete all information from the session every day
and this isn’t what I want!
The session information should not be deleted from the user manager.
has someone an idea?
I use RouterOS V6.1
Thanks.
Regards
Zeup
I had a new idea:
:log info "Start"
:local count
:local date [/system clock get date]
:local x 1
:local i [/tool user-manager session print count-only]
:local sess
:do {
:set sess [/tool user-manager session get number=$x value-name=from-time]
:log info "$sess"
:if ($sess = $date) do={
/tool user-manager session print append file="DailyReport" where from-time=$sess
:set x ($x + 1)
} while ($i > $x)
#/tool e-mail send to="xxx.yyyy@aaaa.de"  body="Bewegungen im TestNetz" subject="Bewegungen im TestNetz " file=("DailyReport.txt")
:log info "END"
but i can’t compare from-time with the date of today, because the date in from-time is store as a string and not as time value.
If I can convert a string to time value then my script will work.
Or can I cut a string from “mmm/dd/yyyy hh:mm:ss” to “mmm/dd/yyyy”
If that work I need not to convert the string.
But How??
Have someone an idea??
Regards
Zeup
