Daily reset | IP hotspot user
Hello everyone,
I’m new to the forum and would appreciate some advice regarding a Hotspot setup.
I am currently running a simple configuration where users are allocated 1GB of data per day, and the quota is reset nightly via a scheduler.
Issue is that some users are reporting that they receive the “traffic limit reached” message well before consuming the full 1GB of data.
I have the same configuration deployed at other sites without any similar complaints. Any insights would be greatly appreciated.
RouterOS 7.21.2
model = RB2011UiAS
/ip hotspot user profile
add name=1000MB_Profile rate-limit=1M/1M
/ip hotspot user
add limit-bytes-in=1000000000 limit-bytes-out=1000000000 name=user1 profile=1000MB_Profile
/system scheduler
add interval=1d name=reset_quota on-event="/ip hotspot user reset-counters" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2025-09-06 start-time=23:59:59
add interval=1d name="disconnect user" on-event="/ip hotspot active remove [find]" policy=reboot,read,write,test,password,sniff,sensitive,romon start-date=2026-02-11 start-time=23:59:30
I want to ask you, no offence: Isn't the "limit reached" selfexplaining enough?
For me eg. someone listens to the streamed music or browses TT/YT/video heavy portals that tend to load videos without demand. The result is limit reached. Try to check transfer data for each user and you will find the answer.
And how can he say that?
Where's the evidence?
And how much is this difference?
How does he measure it?
Does he say he used "only 931 Mega of 1 Giga"?
(1000000000B = 1GB = ~931MiB)
(1745337664B = 1GiB = ~1745MB)
@rextended
Quote of the day (Dr. House M.D.) :wink:
“I don't ask why patients lie, I just assume they all do.”
I had someone body tell me once that “they had not downloaded a single thing all day, all they had been doing was watching Netflix. How could that have used all their data, the system must be broken”
It seems to me that more than help with RouterOS, you need a teacher to teach customers about data...
Netflix all day, maybe on multiple devices...
I believe the gigabytes will run out in... 1 hour?
Calculate how long it takes to download 1G with a continuous download...
Data usage on Netflix varies depending on video quality,
ranging from about 0.3 GB (300 MB) per hour for low definition (360p), to over 7 GB per hour for Ultra HD (4K).
Standard definition (SD) consumes about 0.7-1 GB/hour,
while high definition (HD) consumes about 3 GB/hour.
Dude chill out - it was funny story about someone who did not understand data….. I was not asking for any help, just mentioning something funny someone said to me once.
? :face_with_raised_eyebrow:
Yep, do an investigation of how much data they get before they are cut off. Really, that would be basic information to establish that there is actually a problem. And to share with us.
