Trying to configure multiple CRS326 switch’s per the attached diagram. Everything from switch 1 to the router is working as expected. From the router and laptop I can access switch 1 using mananagement IP. When I connect a laptop to switch 1 on ports 1-22 I can get online. When I connected switch 2 and configure it exactly the same as switch 1 except with a different management IP, switch 2 will not communicate with switch 1 or the router.
Post configs from sw1 and sw2, without it we cannot see whats missing.
Solved! Reset the switch to defaults and reconfigured. Everything working as expected.
