data extensive loss Problem
hello, i would like to point to a problem that im facing with point to multipoint configuration with RB433 having 2 wireless cards( wmr400 - senao). the problem is that the clients are connecting and disconnecting around 10 times per 5 mins eventhough their signals is great (-44 to -59). Customers are complaining of disconnections… any solution ?
Thanks in advance
Do you use wireless-test package?
Seems like you would want to check this out: http://forum.mikrotik.com/t/strange-reassoc-problem/27210/1
what channels are you using ? use channels with differentiation of 150mhz i had that problem and I used different channels and it worked for me.
best regards Remus
