"data from unknown device XX:XX:XX:XX:XX"
I know this was mentioned in another post but I’m really frustrating with this issue in my network.
The following is an example of my log:
As you can see is full of the same issue caused by a cheap Chinese IP camera which (for the moment) I can’t replace. This is the only device which although it is accessible from the network and seem to serve fine its purpose it generates there annoying communication errors.
Unfortunately the camera settings regarding its WIFI interface is dead simple and there is nothing to alter there except IP settings.
So my last line of “defence” is to set the router to ignore these events (preferably from this device only). Is there any way to set filters on log?
I know it sounds stupid, but as far I can tell from my previous search on web resources there is no solution on cases like this (correct me if I’m wrong).
Can somebody tell me if there is any solution this?
I love log… it gives me a complete control about what’s going on on my router but these log lines are driving me insane.
