We have an ADSL 2+ connection into Ether 1 with a 1TB data limit
We want to split this 1TB data limit across 4 LAN’s with the following limits:
eg: Ether 2 - 300MB, Ether 3 - 300MB, Ether 4 - 300MB, Ether 5 - 100MB
These data limits are monthly and will reset at the end of each month
Can someone please point me in the right direction to setup this.
What would happen if an ethernet interface reaches the limit ? You want to stop connection or lower the bandwidth or … ?
Are all clients on the same subnet, or in 4 differents subnets?
Thanks for the responses. is there s way to automatically reset the counters? this isn’t something we will be managing proactively for the client so if it can be set to reset after 30 days that would be great.
You wish!
If you can do it from the CLI, you can script it. If you can script it, you can schedule it. If you can schedule it, the router can do it itself.
