Data Packages
Are there any options to add data packages in the user manager system?
At the moment I can find all the time based stuff, but a lot of the hotspots we manage are based on time and data (as everyone is charged for downloads in Australia :frowning: ). If not, are there any plans to add data options in the future?
Here’s an example of what options we normally offer (and would love to be able to offer via the user manager)
Packages:
Packages include both data and time, anything else is optional
Name Description Cost
Time: 24 Hours Included Data: 200Mb $10.00
Time: 1 Months Included Data: 500Mb $25.00
Time: 3 Months Included Data: 1500Mb $60.00
Time: 6 Months Included Data: 3000Mb $100.00
Time: 12 Months Included Data: 6000Mb $180.00
Data:
You can add more data, however it’s unusable without a valid subscription
5Gb Data Plan Adds 5000MB $25.00
10Gb Data Plan Adds 10000MB $40.00
20Gb Data Plan Adds 20000MB $70.00
Regards,
Omega-00
It is possible to limit user’s traffic limit, however it is not possible to increate traffic amount by payment.
Administrator cold change this data by hand, but you cannot define it (like 5Gb traffic costs 10$).
Is there anywhere I can put this as a suggestion for the newer versions, or is here good enough. :slight_smile:
Yes, here is fine. Anyway we have plans to add support for such option in the future.
Thanks muchly
[Edit] Moved stuff to feature request page.
