Hello all I have a question regarding “data rates” and “b / g” I currently operate with b / g and all data rates make any difference if the can have improvement in signal quality?thanks
If you see that your users CAN’T connect with 54, 48 or 36 Mbps datarates, disable this rates. This will improve your connections quality, due to less try of “up-speed, test-speed, fail-speed, down-speed” automatic calculations in the cards and CPEs.
some clients are likely to have links to these speeds, but some do not recommend what to do you know if you want to operate only in the channel b wins what network speeds greater spread tightening or what? Thanks
b rates and g rates are diferent. You can configure both diferent ; )
try to remove 54 or 48 if you don’t need it.
If you are giving 2 Mbps connections to the users, why you need 36Mbps+ rates? : P!
pass only if b then automatically lowered rates 11,5,5 and 2 MBs, you recommend that lowers rates or is it better to be assigned only to channel b? thankss
But, what you need/want to do exactly?
nothink i want to esatblish connection nothink more
Ok,
If you want to improve the signal, due to bad receiving signal, you can use 802.11b, instead of b/g. You will notice a bit better signal, but data rates doesn’t matter.
Notice that if you change to “only b”, all the users will work slower.
why I work with the supply slowly with a 512kb network may have an impact on channel switching b? thanks
If you need only 512, switch to b. No problem.
ok thanks,i have another question for you can you tell me what is Nstreme to wireless table in pci card to me is disable if i enable what he make
?thanks
