Data Sharing in RouterOS
Hi can anyone please help me…
I am trying to share data between two PC’s using Mikrotik RouterBoards but somehow right now i am not able to do that…i have also injected the 5GHz XR5 Wireless Cards in mini PCI slots but still problem is not solved…
Please i need your guidance ini this regard…Just guide me that how can I share data between two PC’s…i just wanna know the right procedure…please guide me if anyone has got any idea just how to share data…
regards…
It’s not clear what you mean by data sharing. Please explain what exactly are you trying to achieve.
If you want to forward packets between two wireless clients, both connected to the RouterOS AP, then select “Forwarding” on eather the wireless card or for each of the client access rules.
I configure my RB433 as AP and RB600 as Client.on both routers i have XR5(Ubiquiti Networks)
card.configuration of both AP and Client is according to
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_without_using_WDS_(EoIP)
After scanning i found my AP in Scan but when i connect it.it does not give responce
Wireless connectivity is fine but the prob is that both the PC,s not connected.I just want to ask
what type of configuration i should give to Both PC’s(For example TCP/IP Settings).So that both the PC’s connects to each other in order to share data(Just like Ordinary Sharing)
With Best Regards:
Still not entirely clear.
But if you are using simple ap-bridge mode (on 433) and station mode (on 600), i don’t see the requirement for EoIP.
If you had in mind extra security (with less overhead requirement), you could consider pppoe instead.
Look what we are trying to do is to share between two PC’s just like we share on PC’s in a typical Network…the problem we are facing is that we configured RB433 in AP-BRIDGE mode and we configured RB600 in Client mode…you are also right about the solution that you have proposed that since the boards are configured in AP Client mode there is no need to configure EoIP…that is also the point when Data Starts pouring in through XR5 Wireless cards…Winbox shows the RX and TX has started pouring in and that both cards have properly synchronized but still no ping on either side…now all i wanna know is that whether there is some problem in configuration or the winbox that we are using is not a licensed one…
data sharing that we are trying to do is simple sharing that takes place between two PC’s on a typical Network…we just want to transfer data from PC to another PC using XR5(Ubiquiti Networks) wireless cards and still we are not able to do that…please guide us in this regard that how can we share data between two PC’s using Wireless XR5(Ubiquiti Networks) cards…
Regards…
