Hello. I’m finally migrating from v4.0b3 to v6 (6.38.7 to be exact) and this data source code isn’t working any longer:
rate(diff64(oid_raw(“1.3.6.1.4.1.14988.1.1.2.2.1.7.16777218”)))*8
Any ideas what I need to modify? The OID is valid (from HTB in RouterOS and works on v4.0b3.
Thank you!
EDIT: It seems to be a problem with “diff64”. I have another similar code line (the OID is different) on a device label that works, but the value being returned from the OID poll is much smaller. Could the number on the OID above, which is bytes that traversed the queue tree queue, simply be too large even for diff64? By the way, when I say it doesn’t work, what I mean is it only returns the number 0.
So, “[rate(diff64(oid_raw(“1.3.6.1.4.1.14988.1.1.2.2.1.7.16777218”)))*8]” on a device label returns 0 and it says 0 through multiple polling cycles.
This, "[oid_raw(“1.3.6.1.4.1.14988.1.1.2.2.1.7.16777218”)] on the same device label returns the bytes value as expected.
This, “[rate(oid_raw(“1.3.6.1.4.1.14988.1.1.2.2.1.7.16777218”))]” on the same device label returns the bytes divided by the time elapsed since last poll, as expected.
