When I boot the router and look at my log, I see that the clock shows December 31, 2001 for the first 14 seconds or so and then changes to the correct date and time. Is this by design or do I need to configure something? humm, or maybe that is the date/time when the OS was installed?
dec/31/2001 17:00:07 system,error,critical router was rebooted without proper shutdown
dec/31/2001 17:00:15 interface,info ether1 link up (speed 100M, full duplex)
dec/31/2001 17:00:16 interface,info ether2 link up (speed 100M, full duplex)
feb/06 22:35:15 script,info Speed Test executed in 00:00:00.204345 seconds.
Yes, fully booted and can contact the NTP server to get the correct date/time. Mine defaults to jan/01/1970, but I have older firmware so that could be the difference.
It is an unfortunate problem, but there isn’t a battery or anything on the routerboards to hold the time… so until it can hit an NTP server (e.g. your internet connection is up) thats the time you get.
