Mikrotik, will the date in the logs be corrected???
In the logs, logs from previous days seems to have the date, but no date in logs for the current day.
I tried to log a IP Abuse for possible VoIP fraud and sent the owners of the IP range a text file with extract from my logs, but the freaken date is not on there!!
How will this hold up in a court of LAW?
16:36:11 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
len 585
16:36:12 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:14 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:18 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:22 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:26 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:30 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:34 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:38 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
16:36:42 firewall,info forward: in:ether1 out:bridge1, src-mac 44:4c:a8:ba:00:1d, proto UDP, 163.172.205.176:47283->192.168.168.6:5060, NAT 163.172.205.176:47283->(<WAN Address>:5060->192.168.168.6:5060),
len 585
