Everything is above my pay grade.
You can have a look overhere:
http://forum.mikrotik.com/t/day-of-the-week-and-more/131557/1
https://github.com/phistrom/datetime-routeros/blob/master/README.md
And a scipt from which you can build your own:
### calculate diff between two dates - yoan tanguy 2017
# format: :global date1 "jan/05/2017 10:00:00";:global date2 "may/15/2018 12:30:00";/system script run diffDate
# expected date format : month/day/year hours:minutes:seconds (ex: mar/14/2017 09:13:54)
:global date1
:global date2
# date to array format :
# m a r / 1 4 / 2 0 1 7 0 9 : 1 3 : 5 4
# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
:local date1month [:pick $date1 0 3]
:local date1day [:pick $date1 4 6]
:local date1year [:pick $date1 7 11]
:local date1hours [:pick $date1 12 14]
:local date1minutes [:pick $date1 15 17]
:local date1seconds [:pick $date1 18 20]
:local date2month [:pick $date2 0 3]
:local date2day [:pick $date2 4 6]
:local date2year [:pick $date2 7 11]
:local date2hours [:pick $date2 12 14]
:local date2minutes [:pick $date2 15 17]
:local date2seconds [:pick $date2 18 20]
# month to decimal converter - http://forum.mikrotik.com/t/compare-dates/53609/1
:local months ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
:set date1month ([:find $months $date1month -1 ] + 1)
:set date2month ([:find $months $date2month -1 ] + 1)
:global globalDiff
:local yearDiff ($date2year - $date1year)
:local monthDiff ($date2month - $date1month)
:local dayDiff ($date2day - $date1day)
:local hoursDiff ($date2hours - $date1hours)
:local minutesDiff ($date2minutes - $date1minutes)
:local secondsDiff ($date2seconds - $date1seconds)
# handle diff by converting in seconds, avoid negative hours/minutes/seconds (ex: jan/01/1970 09:00:00, jan/02/1970 08:00:00 must give 0 days 23:00:00 and not 1 days 0-1:00:00)
# 1 days 23:30:10
# 1*24*60*60 + 23*60*60 + 30*60 + 10
# ($dayDiff * 24*60*60) + ($hoursDiff * 60*60) + ($minutesDiff *60) + $secondsDiff
# ($dayDiff * 86400) + ($hoursDiff * 3600) + ($minutesDiff *60) + $secondsDiff
:local secondsGlobalDiff
:set secondsGlobalDiff (($dayDiff * 86400) + ($hoursDiff * 3600) + ($minutesDiff *60) + $secondsDiff)
:set dayDiff ($secondsGlobalDiff / 86400)
:set secondsGlobalDiff ($secondsGlobalDiff - ($dayDiff * 86400))
:set hoursDiff ($secondsGlobalDiff / 3600)
:set secondsGlobalDiff ($secondsGlobalDiff - ($hoursDiff * 3600))
:set minutesDiff ($secondsGlobalDiff / 60)
:set secondsGlobalDiff ($secondsGlobalDiff - ($minutesDiff * 60))
:set secondsDiff $secondsGlobalDiff
# check if date1 is older than date2 to avoid errors in calculation
if ($yearDiff < 0) do={
:return "error : date1 should be older that date2 (year check), exiting"
} else={
if ($yearDiff = 0) do={
if ($monthDiff <0) do={
:return "error : date1 should be older that date2 (month check), exiting"
} else={
if ($monthDiff = 0) do={
if ($dayDiff < 0) do={
:return "error : date1 should be older that date2 (day check), exiting"
} else={
if ($dayDiff = 0) do={
if ($hoursDiff < 0) do={
:return "error : date1 should be older that date2 (hours check), exiting"
} else={
if ($hoursDiff = 0) do={
if ($minutesDiff < 0) do={
:return "error : date1 should be older that date2 (minutes check), exiting"
} else={
if ($minutesDiff = 0) do={
if ($secondsDiff < 0) do={
:return "error : date1 should be older that date2 (seconds check), exiting"
# check if leap years - https://wiki.mikrotik.com/wiki/AutomatedBilling/MonthEndScript
:local isYear1Leap 0
:local isYear2Leap 0
if ((($date1year / 4) * 4) = $date1year) do={
:set isYear1Leap 1
if ((($date2year / 4) * 4) = $date2year) do={
:set isYear2Leap 1
# find the right amount of days between 2 months
:local daysInEachMonth ("31","28","31","30","31","30","31","31","30","31","30","31");
:local daysInEachMonthLeapYear ("31","29","31","30","31","30","31","31","30","31","30","31");
:local totalDaysBetweenMonths
# same year; yearDiff = 0 so year1 = year2
if ($yearDiff = 0 and $monthDiff >= 1) do={
if ($isYear1Leap = 0) do={
for month from=($date1month - 1) to=($date2month - 1) step=1 do={
:set totalDaysBetweenMonths ($totalDaysBetweenMonths + [:pick $daysInEachMonth $month])
if ($isYear1Leap = 1) do={
for month from=($date1month - 1) to=(($date2month - 1) - 1) step=1 do={
:set totalDaysBetweenMonths ($totalDaysBetweenMonths + [:pick $daysInEachMonthLeapYear $month])
# different year, make concatenation of daysInEachMonth arrays first
:local daysInEachMonthConcatenatedYears
if ($yearDiff >= 1) do={
for year from=$date1year to=$date2year step=1 do={
# if leap year, concatenate the right daysInEachMonth array
if ((($year / 4) * 4) = $year) do={
:set daysInEachMonthConcatenatedYears ($daysInEachMonthConcatenatedYears, $daysInEachMonthLeapYear)
} else={
:set daysInEachMonthConcatenatedYears ($daysInEachMonthConcatenatedYears, $daysInEachMonth)
# must add years count
for month from=($date1month - 1) to=(($date2month - 1) + (($yearDiff * 12) - 1)) step=1 do={
:set totalDaysBetweenMonths ($totalDaysBetweenMonths + [:pick $daysInEachMonthConcatenatedYears $month])
:global globalDaysDiff ($totalDaysBetweenMonths + $dayDiff)
# add leading zeros if necessary
:if ($hoursDiff < 10) do={
:set hoursDiff ("0" . $hoursDiff)
:if ($minutesDiff < 10) do={
:set minutesDiff ("0" . $minutesDiff)
:if ($secondsDiff < 10) do={
:set secondsDiff ("0" . $secondsDiff)
:local d "d"
:set globalDiff "$globalDaysDiff$d$hoursDiff:$minutesDiff:$secondsDiff"
:put $globalDiff
