Hi!
There is a problem, which could not manage to solve.
Of course you need to read read and read manuals.
But as long as there is no full clarity of the text read.
So:
There are users pppoe on mikrotik and they receive the attributes of speed through the FreeRadius.
This is for work in the internet in accordance with the predefined restrictions on tariff.
Now had the task to make moods (defined network 10.0.0.0/8) without speed limits.
Torrents of all sorts, DC hubs.
Need help how to do this.
It is clear that the need to label the packages in the mangle.
And then somehow put a rule in the queue to remove the restriction.
I.e. the user got his pppoe session and scheduler checking pppoe connection.
And then have to run the script changing something in the queue.
At least so the algorithm is seen.
If you examples of how this is solved.
