DCHP issues
Please can someone help out with this:
I want my WAN to use DCHP both for IP address and DNS server because my new ISP only allows for that. I use hotspot but it does not allow my hotspot client access to internet. How do I work around this to be able to allow my hotspot client access client assess to internet.
You can configure DHCP-Client to get Dynamic IP address from your ISP. Also enable default-route as well as use-peer-DNS.
You can have masqurade rule in /ip firewall nat to allow internet to your hotspot user.you can have out-interface=ether1
I have done all you said. The issue is that without a static DNS server address the hotspot is not working. or rather can you help me out with how I can configure my router ip address to be used as DNS address instead of my DNS address.
