DCHP
Hi all have a mikrotik router board and switch my problem is the both want to be the DHCP server with the same IP how do i turn the switch to be a client?
Any help will be great trying to build up my networking skills
Thanks Simon
What switch do you have? If its unmanaged L2 switch, you cant.
Your router can be DHCP server and assign IP’s from its address pool that you create for it on specific interface.
router RB2011UiAS-RM
switch CRS125-24G-1S-RM
what i have done is set it to Bridge and is half working dropping off some hardware like nas servers
Connect using winbox then on the CRS go to
IP > Addresses to delete static IP
IP > DHCP server to disable the DHCP server
IP > DHCP Client to add one to the interface connected to the 2011
thanks will give this a shot tomoz kids kicking me top play
As Pukkita said, do all that and on router enable DHCP server on that interface that you are connecting your switch.
Add address pool that you want and it should be done.
