dd-wrt for rb 600a(please help)
i have a rb 600A
i want install dd-wrt on rb 600A
how?
I don’t know :slight_smile:
Go to http://www.dd-wrt.com/dd-wrtv3/dd-wrt/hardware.html
enter RB-600 and you will get all the information you need.
but this address don`t give me completely information
did you enter RB-600 there? what was the result?
the answer is no support
but i should put dd-wrt on rb600
no - the router can be supported but is currently not and is not in the works
in other words they don’t care what you want, you simply can’t do it because RB600 is not supported by their OS.
You can try OpenWRT instead.
Or use RouterOS which is designed to work best with routerboards.
