Reinstall the routeros 6.46.4 as netinstall.
However, the same problem occurred.
A. PING is communicated to the ISP address.
B. DDNS address is out of communication by calling a 404 or 400 error.
C. quick setup not working!!
D. ERROR COMMENT : (IP CLOUD (DDNS)) router is behind a NAT. Remote connection might not work.
Please help me… I haven’t been working for days…
my network inter-vlan & L2TP VPN!
[cskisa@Router] >/system identity set name=”Router”
[cskisa@Router] >/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
[cskisa@Router] >/interface bridge port
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/1
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/2
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/3
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/4
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/5
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/6
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/7
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/8
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/9
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/10
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/11
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=Gi0/12
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,Gi0/1 vlan-ids=20
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,Gi0/1 vlan-ids=30
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,Gi0/1 untagged=Gi0/2,Gi0/3,Gi0/4,Gi0/5,Gi0/6,Gi0/7,Gi0/8,Gi0/9,Gi0/10,Gi0/11,Gi0/12 vlan-ids=100
[cskisa@Router] >/interface vlan add interface=BR1 name=MGMT-VLAN vlan-id=100
[cskisa@Router] >/ip address add address=200.168.10.1/24 interface=MGMT-VLAN
[cskisa@Router] >/ip dns set allow-remote-requests=yes servers=”9.9.9.9”
[cskisa@Router] >/ip dhcp-client add interface=Gi0/0
[cskisa@Router] >/ip dhcp-client enable 0
[cskisa@Router] >/interface vlan add interface=BR1 name=SUPERMICRO-VLAN vlan-id=20
[cskisa@Router] >/ip address add interface=SUPERMICRO-VLAN address=200.168.20.1/24
[cskisa@Router] >/ip pool add name=SUPERMICRO-POOL ranges=200.168.20.2-200.168.20.254
[cskisa@Router] >/ip dhcp-server add address-pool=SUPERMICRO-POOL interface=SUPERMICRO-VLAN name=SUPERMICRO-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.20.0/24 dns-server=200.168.10.1 gateway=200.168.20.1
[cskisa@Router] >/interface vlan add interface=BR1 name=IBM-VLAN vlan-id=30
[cskisa@Router] >/ip address add interface=IBM-VLAN address=200.168.30.1/24
[cskisa@Router] >/ip pool add name=IBM-POOL ranges=200.168.30.2-200.168.30.254
[cskisa@Router] >/ip dhcp-server add address-pool=IBM-POOL interface=IBM-VLAN name=IBM-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.30.0/24 dns-server=200.168.10.1 gateway=200.168.30.1
[cskisa@Router] >/ip pool add name=MGMT-POOL ranges=200.168.10.10-200.168.10.254
[cskisa@Router] >/ip dhcp-server add address-pool=MGMT-POOL interface=MGMT-VLAN name=MGMT-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.10.0/24 dns-server=200.168.10.1 gateway=200.168.10.1
[cskisa@Router] >/interface list add name=WAN
[cskisa@Router] >/interface list add name=VLAN
[cskisa@Router] >/interface list add name=MGMT
[cskisa@Router] >/interface list member add interface=Gi0/0 list=WAN
[cskisa@Router] >/interface list member add interface=MGMT-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=SUPERMICRO-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=IBM-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=MGMT-VLAN list=MGMT
[cskisa@Router] >/ip firewall filter add chain=input action=accept connection-state=established,related
comment=”Allow Estab & Related
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN comment=”Allow VLAN”
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN dst-port=53 protocol=udp
connection-state=new comment=”VLAN DNS ACCESS”
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN dst-port=53 protocol=tcp
[cskisa@Router] >/ip firewall filter add chain=input action=drop comment=”Drop FTP,SSH,Telnet from inbound”
dst-port=21,22,23,137,139,445 protocol=tcp
[cskisa@Router] >/ip firewall filter add chain=forward action=accept connection-state=established,related comment=”Allow Estab & Related”
[cskisa@Router] >/ip firewall filter add chain=forward action=accept connection-state=new in-interface-list=VLAN
out-interface-list=WAN comment=”VLAN Internet Access only”
[cskisa@Router] >/ip firewall nat add chain=srcnat action=masquerade out-interface-list=WAN comment=”Default masquerade”
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/1 ingress-filtering=yes frame-types=admit-only
-vlan-tagged
Number : 0
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/2 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 1
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/3 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 2
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/4 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 3
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/5 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 4
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/6 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 5
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/7 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 6
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/8 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 7
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/9 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 8
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/10 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 9
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/11 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 10
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=Gi0/12 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
Number : 11
[cskisa@Router] >/ip neighbor discovery-settings set discover-interface-list=MGMT
[cskisa@Router] >/tool mac-server mac-winbox set allowed-interface-list=MGMT
[cskisa@Router] >/tool mac-server set allowed-interface-list=MGMT
[cskisa@Router] >/interface bridge set BR1 vlan-filtering=yes
[cskisa@Router] >/interface l2tp-server add name=KWS user=””
[cskisa@Router] >/ip pool add name=KWS ranges=200.168.40.2-200.168.40.254
[cskisa@Router] >/ppp profile add change-tcp-mss=yes local-address=200.168.40.1 name=KWS remote-address=KWS
use-encryption=yes
[cskisa@Router] >/interface l2tp-server server set default-profile=KWS enabled=yes ipsec-secret=spacezone18!@#
use-ipsec=yes
[cskisa@Router] >/ip cloud set ddns-enabled=yes ddns-update-interval=1m
[cskisa@Router] >/ip firewall filter add action=accept chain=input comment=L2TP dst-port=1701 protocol=udp
[cskisa@Router] >/ip firewall filter add action=accept chain=input comment=L2TP dst-port=4500 protocol=udp
[cskisa@Router] >/ip firewall filter add action=accept chain=input comment=L2TP dst-port=500 protocol=udp
[cskisa@Router] >/ip firewall filter add action=accept chain=input comment=L2TP protocol=ipsec-esp
[cskisa@Router] >/ip firewall filter add action=accept chain=input comment=L2TP protocol=ipsec-ah
[cskisa@Router] >/ppp secret add local-address=200.168.40.1 name=NA password=NA profile=KWS remote-address=200.168.40.18
[cskisa@Router] >/interface ethernet set Gi0/1 arp=proxy-arp
