Hi Guy’s I use a company call Microtech for my DNS and I trying to workout how I intergrate this into a script : Specifically the single line authentication and update if possible.
Dynamic DNS update protocol
Microtech’s DNS update protocol is described below. This simple to use protocol can easily be integrated into scripts, routers etc.
The HTTP requests can be made in HTTPS (secure) or plain HTTP modes. HTTP requests will be accepted on ports 80 and 8147. Port 8147 is usefull for bypassing ISP’s stealthy proxies. HTTPS requests are accepted on port 443.
Single line authentication and update
“http://www.mtgsy.net/dns/update.php?email=username&pass=password&hb=0&ip=0.0.0.0”
Variable Function description
username This can be either the account username (email address) or the name of an individual dynamic domain on your account. If the account name is specified all domains on the account are updated. Update single domains separately by specifying the domain name.
pass The account password
hb 1 or 0. Indicates whether our system should send out heartbeats and set the domain offline if they are not responded to.
stealth 1 or 0. Indicates whether the offline page redirection should be made in a hidden frame to attempt to retain the original URL in the browser.
port HTTP Port number. If port is 80 DO NOT USE. This option is used if your ISP blocks port 80 and you want to run a web site on an alternative port number. Please note, as this is designed to redirect HTTP requests it will only function on the ‘www’ record of your domain.
ip Optional. If included sets your domain to point to the specified IP address. If not specified the system will auto detect your IP and set it accordingly.
offlineurl The URL you would like http visitors re-directed to if you are marked off-line. Must a FULL url in the format ‘http://www.youdomains.com/url’.
offlinetext The message to display to http visitors when you are off-line
mx Specifies an MX record. Specify server name in full with a terminating
Thanks Mark
