DDNS
huh? already there for a long time.
I think (guess) he’s talking about support for dyndns.org et al…
AFAIK, only changeip.com DDNS is supported native on 2.9.
Best regards,
Christian Meis
also the industry standard DDNS protocol is supported
http://www.mikrotik.com/docs/ros/2.9/tools/ddns
although none of the commercial services use it. this is for home made applications
i did signup for changeip.com but i have some problems and there support didnt reply to me " whats should be placed in address?? can any one give me hint on how to ues it?
i already check this http://www.mikrotik.com/docs/ros/2.9/tools/ddns
i need some help
my ip is been change every day from my provider wo how could i submut it?
This script is for 2.9:
http://wiki.mikrotik.com:3280/wiki/Dynamic_DNS_Update_Script_for_ChangeIP.com
In ddns-host the default is *1, this means update all hosts that are part of set/group 1. If you wish, enter a single fqdn (fully qualified domain name) or a group name and it will only update that specific host.
I do not believe we saw email from you otherwise it would have been replied to - we are very quick to reply typically less than a few hours. If you have troubles still post in these forums the problem and I will help.
Sam
thanks alot sam,
but i uesd to have problems with my mail provider even with MT,
so i think i should post it here, so all ppl take benfit of this,
i apply for dns not ddns in your site and its free,
do you have free DDns or i have to buy one
the currently one i have i think i have to LOCKED ip to the domain
please sam clearfy this thing,
regarding the script
what shall i change on this “global ddns-lastip 0.0.0.0/0”
Are you running 2.8 or 2.9?
We offer both free dns as well as paid dns. The free dns is using our subdomains, paid dns is when you use your domains. We call it ddns, it’s is just dns with the ability to update it using a device and a really short ttl.
The script should be exactly as is it posted in the wiki, just modify the 4 lines at the top with your information. Nothing else should be changed.
Sam
i did it but still using the last ip address
what should be placed with In ddns-host the default is *1
