But from few days I’m monitoring that some of my users IP are listing within “DDoS Attackers List” (see attached file for reference) i.e. IP Range with 172.16.x.x. So I disable this rule from IP Firewall → RAW Tab ( just now) so that users can still use internet.
Question:- I need to know is there any way that I can fix this issue originating from user END?? or Is there any way I would make a rule or any script so that my user having 172.16.x.x ragne never fall in DDoS attacker List??
Please suggest, if any workaround solution is there??
The more important question is why are your users getting caught by your rules.
Suggest the rules need adjusting !!!
If all a hacker needs to do is mimic a WANIP address…
