DDOS attack need help
hello i have many ddos attacks who can help to configure my mikrotik to stop that ? thx
@anav is waiting your reply from 2022
http://forum.mikrotik.com/t/new-bee-questions-about-firewall/155373/1
Would you like help without even thanking or replying?
Ask your ISP, you can not do anything useful for stop DDoS, except close all your open services to the world, that cause the attacks.
hello its long story its very important for to let at least 1 opened port can u help me ?
I already gave you the correct answer.
can i see u in private im really confused and this ddos attack will make me heart attack soon :frowning:
Isn’t it clear to you that only and exclusively your ISP can do something?
Whatever you do, however, is completely useless.
(Aside from shutting down all internet services you provide, which attract attacks)
What are the symptoms of the so called “DDoS attack” and how did you realize it was one?
i have a application on linux server who use 1 port one guy send me a flood attack when i start using it after only 5..10 mins the router crash
Is not exactly the same thing…
If you don’t explain yourself well, how do you expect to have correct help?
One person flood your connection. This is “many DDoS attacks”?
Drop on /firewall raw prerouting his IP.
il newbee on security i buy this mikrotik to secure trafic from my local server to my remote vps ( ovh vps ) in way to let traffic only from a specific ip to specific ip and all all other trafic will be blocked
still confused if we can make a direct contact will be good pls !
https://mikrotik.com/consultants
  1. Provide a detailed network diagram
  2. Post complete config
    /export file=anynameyouwish {prior to posting here, remove router serial#, public WANIP information and any keys}
@rextended, whenever you post make habit of checking mail :slight_smile:
looks like was not so urgent after all
1- network diagram
ubuntu server with cccam server with 1 port opened 9011 the local network conect to vps
this attached config , what i want is to close all incoming trafic and all outgoing trafic only will use 9011 to conect to specific vps ip
# may/07/2023 17:09:37 by RouterOS 7.2
# software id = N19D-NGAV
# model = RouterBOARD 750G r3
# serial number =
add admin-mac=64:D1:54:A0:C8:01 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=GUA24328442
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
    192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment="serveur cccam11" dst-port=9011 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.88.251
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Africa/Algiers
/tool mac-server
/tool mac-server mac-winbox
the first aproch is to close all all incoming trafic and all outgoing trafic then i will open and manage desired port
Unfortunately, Mikrotik ROS has no ability to stop DDOS attacks. If it’s important, you simply have to supplement or replace it with another solution. However, for other common questions regarding firewall settings, you might get good help from folks in this thread.
For tips and suggestions regarding DDOS protection, Google for example “firewalls that protects against ddos attacks”.
u can see attached the SYN flood
if 154.54.220.138 traffic is not relevant or important to you drop it
/ip firewall raw
add action=drop chain=prerouting src-address=154.54.220.138
lowering tcp timeout can help
set tcp-established-timeout=16m
