I have a RB3011 that I just attempted to upgrade. When it booted back up it got stuck at a white screen. Never goes any further. Won’t netinstall or reset with the switch in the back… literally just boots to the white screen and nothing else…
Already emailed mikrotik and the distributor… but it seems dead. Any ideas?
Looks like this… So far I have tried the reset button, serial port, powering via POE, … nothing works. All of this from the upgrade. Both the blue and green light by the USB port are on…
I have the same problem. Only white screen appears, the blue+green led is lit near USB port. Also tried everything. Measured serial TX & RX with oscilloscope, RX is snapped to 3,3V, but TX is stays at 0V. Can’t see any hw failure on PCB, caps are in good condition (visual inspection only). Current reading is ~130mA @ 24V.
Please help, how can i save my board? (Warranty is off by now)
