Mikrotic Manufacturer
Waiting 802.11ac product.
Thanks…
Thanks…
Name is MikroTik.
+1 ![]()
No, it is MikroTik
Corrected ![]()
Ok, we have the name of the company down.
Is there an 802.11ac mini-pci radio board coming soon?
Hello ykutlu,
perhaps not made by MikroTik itself but if you get a mini PCIe 802.11ac wireless card
you can try it out in one or more MikroTik routers. Perhaps with a Qualcomm-Atheros chip set.
Would this also being something for you?
It simple does not work until MT writes a driver for the card.
Gesendet von meinem GT-N7000 mit Tapatalk 4
For sure nothing will work without a driver inside the OS, but this is in my opinion
the faster way if someone brings out a mini PCI or mini PCIe wifi card with a chip set
from a vendor like Qalcomm-Atheros, or am I on the false road now with my thinking?
If MT decides not to work on a driver (because they’re busy doing other stuff) it doesn’t matter what chip is on your unsupported card.
