Deassigned and Assigned for most of my IP address.
Hi Everyone,
Hope all are feeling good, based of the situation.
Anyway, need your professional assistance.
I have MikroTik 4011 that connect to Ubiqiti AC pro.
The log fills itself with the message: Deassigned and Assigned for most of my IP address.
Can’t really figure out why it’s constantly doing it. Is it a problem, or does it burden the router?
What can I do / change in the router paramers In order to prevent it.
In fact it drives me crazy.
I’m using two AC pro connect controller to the MikroTik.
Thanks in advance !
Check inside your DHCP server the lease time… set it to at least 2-4 hours or so…
Thank you for your fast reply.
It’s already set to 1 day.
Are there any other fields that I should change?
Thanks in advance!
Is your Router updated to the Latest ROS?
Also to what devices is that happening and how often?
Also you can export your config with hide-sensitive, post it inside code tags, and we can take a look there…
Also you could post a part of your log…
Are the wired devices doing this, or just the wireless ones?
