Debian Wheezy i386 on RouterOS X86 (solved)
Is it possible to install debian wheezy i386 into a KVM image under RouterOS x86?
I try to add a netinstall iso into it and it shows running. But I cannot access the kernel for installation.
I mean, I cannot use the console within Winbox to see the netinst message during installation. At the same time, I cannot access via VNC.
Please advise how to make it work.
Why do you suppose it should work ?
I am able to have openwrt as a KVM image under router OS but I want to use debian which I am much familiar. I can have a bigger size image i.e. around 2GB.
This is why I ask if there is guide to install debian i386 as a KVM image under routerOS x86.
I am now able to connect and install Debian Wheezy.
What I need is to create 2 interfaces for the intended KVM image - one is static which is for VNC access and the second one is dynamic which is just like the virtual ethernet for the KVM guest.
Once I did so, VNC can see the console message and I can proceed to the usual installation.
Without the static one, no VNC access.
Without the dynamic one, not able to do net installation
