Debug script error???
When RouterOS (7.2.3) logs this type of errors:
script error: error - contact MikroTik support and send a supout file (10)
how to find out what is wrong?
If you you have many scripts, warning should at least give what script name that fail. Even better, what line number.
When the script is compiled, are lost all lines references and script name on executed code.
for example:
:put "line 1"
:put "line 2"
are converted before run to
(eval /putmessage=line 1);(eval /putmessage=line 2)But the “line 1” and “line 2” is only on text I put on… put
But why not show what failed?
(eval /putmessage=line 2) Failed
It seems to not be one specific script. All the script running gives it data. Router may run out of memory (95% used) or an other bug. Since I am far away from this router at the moment and I do not see other problems, I will wait with reboot/upgrade from 7.2.3. (Waiting for 7.x.2, 7.5.2 or 7.6.2 etc)
